imported_tweeter
- Joined
- Jun 27, 2006
- 11
model 15028-07596
replaced impeller, although old one looked o.k.
took carb apart, has cork float-seems good, all needles and seats are clean, one coil is all cracked, other one seems newer but has some minor discoloration, how can it be checked?, points are servicable and condensers well how can they be checked. Seems to me that the boys working for Ole used the same coils/points for all their small motors but different condensers, why? Lower unit was dry but spins quietly, should it be opened up or just add hypoid?
Replaced all fuel/air lines under shroud. Tank is spotless inside.
Under shroud it is so clean you could eat off it. Don't think this baby has many hours on her. The tiller bracket is broken just in front of the fuel connector on the motor and it leads me to believe that this happened soon after the motor was originally purchased and it was just left to "rot". Is the bracket made of aluminum and if so can it be TIG welded?
Thanks Tweeter!
Thanks Tweeter!
