nineteensixtycaddy
- Joined
- May 21, 2008
- 74
ok... if you've read my past postings about this motor, I've since taken it out a few more times, got it idling nicely, starting the first pull, etc, doing great.. but all the sudden it started rattling. I found out it was the screws for the pull start, and took it off, as I've got a battery to start it now. Well, then.. it starts having trouble shifting into reverse. I found that I had the cable adjusted wrong, and fixed that, but then, it starts having trouble staying in forward gear. I"m like huh? what the? So.. I look at it with the cover off, staring, and found that the gear select lever, has a screw holding it together, and it's come loose. So I tighten it with a lil threadlocker, and thought it'd be fine the next day. NOPE. Goes into reverse fine, away from the dock, goes into gear fine in drive, and then pops right outta gear. I hold the lever down into forward, and it tries to pop out again, over and over it keeps trying to pop out almost in a rhythm. So... I wrestle it back to the dock, and bring her home. Screw holding the gear select lever is still fine, but it just won't stay in gear.
Any suggestions?
or is this thing toast ??? ( I hope not)
Any suggestions?
