asdasc
Thread starter- Joined
- Aug 28, 2008
- 681
I am rebuilding the lower unit on a 1959 Johnson 18HP. It leaks water into the lower unit, I think thru the shift stem seal. While disassembling it, I noticed the end bearing on the gear shaft at the forward end 'looks' like it is cracked, but it could be intentional for oil passage or something. I also have questions about the dimples where some pin in the housing hits it. Is that normal?
Lastly, any hints about driving out the seals on the top of the lower unit where the driveshaft and gear select go thru? How about removing the seal on the prop shaft?
I wish I had an exploded view with the part numbers. I may have to break down and buy the parts catalog. Thanks for your help. I am learning a ton. I was able to get the carb rebuilt and the ignition parts all replaced. It runs great now, just need to keep gear oil in it!
