Re: 59 Johnson, Rings?
Hippie,
Here's my take, and I am nowhere near the level of a lot of the members here. Run a compression check. Anything over 100 and both within 10% are considered good.
If you have one low cylinder, you might need to decarb (search for "decarb") which will clean that motor out.
If I recall, you had said at one point your motor sat for quite awhile. Get her going, run her in the water for awhile, and see how she does. You could have a leaky gasket or seal somewhere.
My '57 had one "bad" cylinder. Compression was 115/80. It was sticky rings on the low cylinder. A decarb fixed it, brought it up to like 108. I just dumped some Seafoam in the cylinder and left it sit for 2-3 days, drained it, then run it around the river. Fixed 'er right up.
Although you never know how a motor was maintained, one that sits for a long time or maintained marginally, could develop sticky rings, leaky gaskets, etc.
Mine ran like an unleashed beast once I got her going. Got rid of it because it was just too darn heavy for my little runabout.
Good luck
Rick
