5L efi ....brand new rebuilts.....no start/spark
oops!
ok.....
i have a 05 5L (twins) with efi.
i just installed new ecm's......one engine fired and ran...the other didnt.
the non running motor has no spark.
i swapped the ecm to the non running motor.......no results.
swapped the two relays......same results....nuthin...
swapped the coil.....no results.
still no spark.
any suggestions as to where to go next?.....
thanks my friends
oops
dubs283
Re: 5L efi ....brand new rebuilts.....no start/spark
post a serial number/model info for the engine and what type of igniton
oops!
looking now for the numbers.......everything was changed.....
as far as the ignition....im not sure.
oops!
ow320727
mcm 5l mpi
dubs283
5 amp fuse close to the battery (16 ga wire) if you have DTS that is
crank position sensor disconnected/faulty
oops!
thank you....checking now
oops!
fuse blown......changed.....still no spark....
(again thank you for the fuse tip....i was wondering what the heck they were......lol)
any other suggestions?
dubs283
well those two were off the top of my head
i don't keep manuals/tech guidebooks at home so I can't use a cheat sheet for ya here
to fully t-shoot the crank sensor your gonna need a CDS computer - merc dealer
otherwise, just check over the dumb little things - in your case you have a fully operational unit/parts room right next to a faulty one, most people don't have that luxury
oops!
thank you.......we are running.
with out that fuse thingy i would still be hard at it.... !
while checking the "silly little things" i found the main motor connector (the main line from the helm) to be difficent.....i had to open up some of the pins with a screw driver....and wahoo !
the sweet sound of purring. but if you did not suggest the fuse......i would still be scratching my head !
cheers
oops
