Re: 5w-20 motor oil in the trim pump????
who's (mercruiser, omc, volvo) and what era trim pump are ya working with?
my '75 mercrusier trim pump states (from mercruiser service manual #2) the correct fluid to use is 20w motor oil. ya can't get 20w motor oil best i know. so if ya can't get what is correct what's a fella to do? myself. my system was filled with motor oil, not hydrolic fluid. so i used 10w-30 motor oil to top mine off (when i had a leak, which i don't have anymore due to repair). so far, i've not had problems with this. i'm going on my 7th year of running my present rig.
so if ya can't get 20w motor oil. what is the recommended fluid to use? i've never seen a service bulletin that states what i should use. from what i understand. mercrusier trim pumps will operate with near anything from hydrolic fluid to motor oil. ya just don't mix the two.
i don't know about the detergent motor oil either. i just know what i've got away with so far and after 6 years of service w/o ramifications. the oil in my rig has never been totally replaced though the resiviour has been emptied and refilled. but the lines and rams were not emptied and still had whatever (i assume 20w oil) it came with when i bought the boat used in 2006 or so. i'm assuming i'm running a mix of old 20w + the new 10w-30 i added. i'm guessing half and half. but still both motor oils.
good luck in whatever ya decide to do.
