6.2 mpi timing issue mercruiser om670840
henry1357
Hi everyone
i have just rebuilt my mercruiser 6.2 mpi and all was well until i took it out on the lake
boat running rough sounds like its missing and won't rev fully
tried turning the distributor to adjust the timing but no different
i believe it it is a timing issue and have read that this can only be set with marine software, is this the case or is there another way of setting timing
thanks in advance
henry
MikDee
Banned
I'm guessing you had the distributor out, and now it is back in at the wrong spot. You can't just turn the distributor for a fix. If you have a Thunderbolt IV, or Tbolt 5, there is a special procedure you need to do to set the timing. What distributor do you have?
henry1357
No Title
hi thanks for reply
i have tried turning the distributor but it makes no difference
boat seems to run well and rev up fine on muffs just wouldn't run properly under load
i have attached a pic of the type of dizzy obviously mine is v8
regards
henry
hi thanks for reply
regards
henry
Ayuh,.... My guess is the timin' is bein' set by the 'puter all right,...
It's starvin' for Fuel,... A Lean condition skip,....
henry1357
hi bondo
thanks for reply
i will check that its not starving for fuel tomorrow.
regarding setting the timing i have read that i need to set engine in base timing mode either with a scan tool or by jumping 2 pins on dcl and the set timing at 8 deg btdc
is this correct for my engine
regards
henry
hi bondo
thanks for reply
regards
henry
Donno ain't got one,.... I've Heard, ya stab the distributor good, 'n close, then the 'puter handles it from there,....
Also Heard the distributor caps can give ya issues like yer seein',.....
What caused the need for the recent rebuild,..??
henry1357
when i bought the boat the engine was out as needed a new coupler which had spun, so was sold as a non runner
exhaust manifolds were off as well so i decided to take engine apart and check it for ware before reinstalling.
there was surface rust around dizzy so i removed dizzy and cleaned the rust up.
put it all back together with new gaskets and new coupler aligned engine and it fired up instantly, runs and revs well on muffs.
dropped in the water and engine won't rev over 2500-3000 and has no power, won't get on plane.
sounded like it was miss firing so i assumed it was timing issue
achris
More fish than mountain goat
Bondo is completely correct in that the ECU handles the timing based on engine speed, manifold pressure, air and engine coolant temperature and another handful of parameters. The only way to 'check the timing' is with the computer software and the plug-in adapter for the engine. There is no way to adjust the timing, it's done in the ECU... What you do need is the 'distributor' to be in the right place. If you have moved it too far away, then when the ECU advances the timing the rotor may not be lining up with the post for that spark plug lead properly. There is a set up procedure in the manual for the distributor....
Chris.....
alldodge
Hi everyone
thanks in advance
henry
Are you sure it's missing or does it just lack power to get full running RPM
henry1357
hi everyone after all your advise and reading on the forum i went and changed the fuel, fuel filter/seperator and ht leads. (holding back on dizzy until after test)
the engine sounds much better on muffs than before and i will take it to lake next week to see.
hopefully it will be ok, do you guys think it could be that simple
regards
henry
henry1357
Just one more thing guys
i have put a timing light on my engine just to check, and the timing mark on balancer is a little bit erratic, what I'm asking is should it be dead stable on the mark or is is normal to move back and forth a little
MikDee
Banned
It will probably bounce a little ;)
henry1357
hi mikdee
thanks for quick reply, you have put my mind at rest a little, will know for sure if all is well once i get back to lake.
the timing doesn't go past the mark on engine but moves about 1/4 inch back from mark
achris
Completely normal for MPI....
henry1357
Also guys please listen to my engine on muffs and let me know what you think
thanks again
everyone has been a great help
achris
That sounds like it's missing on one or some cylinders. Using a pair of properly insulated pliers pull a plug lead at a time off and see if the sound changes.
henry1357
hi achris
pulling leads off one at a time nearly stops engine on all leads except 3 and 7, sound doesn't seem to change.
have had new plugs and leads, what could it be
distributor ?
thanks henry
MikDee
Banned
That don't sound good :eek: not running on all cylinders! Check out your plug wiring, firing order! 1-8-4-3-6-5-7-2 clockwise, Port side 1-3-5-7, Stbd side 2-4-6-8, Next check your valve adjustment, loosen till they clatter slightly, then snug up till quiet then 1/2 turn down slowly, do them all, and your done!
