I recently bought a used 2002 Caravelle with a 6.2L Mercruiser. The previous owner had modiifed it. The Bravo I was replaced with an Alpha I SS (low water pickups, no gear lube monitor) and the captains call exhuast was replaced with straight thru the transom exhaust.<br /><br />The day I bought it, on the test drive it ran great.
The first day I had it home and took it out on the local lake, the engine alarms started going off. It has not run without alarming since then.
<br /><br />I have replaced the impeller twice (2nd time replaced the whole assembly). I have also taken it to a shop and had the computer diagnosed. The diagnosis was that I had overheating, low waterpressure, knock sensor, and overspeed alarms. The alarm occurs at 4638rpm (everytime). The gages indicate everything normal (tach, water temp, oil pressure), yet I cannot get it over about 4500 rpm without it alarming.<br /><br />I haven't had much luck with the local repair shops with anyone being able to tell me what is truly wrong with it. Any suggestions would be appreciated (if you think I got screwed on this used, modified boat let me know too).<br /><br />Thanks,<br />J
