6 hp Chrysler (sea king) intermentent ignition problem
kawaboy-zx11
Hi, i have a 1970 6hp seaking made by chrysler, i can get it running in my barrel real good sometimes, and then all of a sudden it dies and when i check it i have no spark. what would cause the spark to just stop while its running? Thanks, Dennis
Frank Acampora
Re: 6 hp Chrysler (sea king) intermentent ignition problem
Pull the flywheel, check the points, and check for broken or frayed wires shorting against the flywheel.
Bad condensers will cause intermittent running and spark loss but they can not be tested. Replacing them is no guarantee that new ones will cure the problem, but they are relatively inexpensive and worth the try.
kawaboy-zx11
thanks for the info, i just found the problem. the flywheel key sheard off... i thought it seemed easier to pull :eek: i dont want it to break again...does anyone know the tourqe lbs for the fly wheel nut? and just to let people know...if you break the flywheel key just go to a small engine repair shop. i got mine for 50 cents :) Thanks, Dennis
Frank Acampora
According to Clymers: 4.4-8HP flywheel nut torqued to 40 Ft. Lbs.
