6 hp Evinrude fisherman
mark121268
there is a plastic peice that sites on top of the pull cord .the teeth have worn off, does any one know or have one i can bye ,sorry not to much infomation on it the ser number is gone . i can send pics of it if needed .again sorry for not having much info on it .
F_R
Re: 6 hp Evinrude fisherman
I would think that a Johnson or Evinrude dealer should have that plastic pinion gear.
ezeke
Pinion-Part # 0318447. Any dealer should have it, or try ishopmarine.com
F_R
It's a bit tricky to replace if you don't have instruction. The recoil spring has to be released and rewound. Not hard to do, just have to know how to do it.
mark121268
WOW i thank you all that was very fast , i have spent weeks trying to get some info on thatpart that i now know to be a pinion gear 8).thanks guys been a big help
x1745
Ne1 has the instructions on how to rewound the spring
I have the Clymer manual but no instruction just pictures of the spring
Do I have to pull out the pin on the pinion?
thks
crxess
You will need to remove the pull start to change the gear.
Disconnect the rope from the handle and feed back into the starter.
Remove the (2) top bolts on starter.
Remove (2) bottom bolts.
Wiggle and lift starter out. - Don't loose the long pin that guides the rope.
Loosely start the lower bolts into the bottom starter plate. Do Not Tighten.
Do the gear replacement.
Set the starter spring into the lower plate and align the spring tab into the slot in the lower plate.
Slip the starter over the spring
Install the long pin
Secure the top starter plate and tighten the lower bolts
Remove the spark plugs
Raise the new starter gear and slide a pliers handles under to hold it up against the flywheel
Turn the flywheel about 8 turns to load the Starter spring.
Feed the rope out and extend it fully and secure to handle
Hole onto the rope, release the pliers and feed the rope back in.
Giver it a few pulls to test everything out.
x1745
Thank for the quick response I will try this tomorrow
:D
