Tim Frank
Thread starter- Joined
- Jul 29, 2008
- 5,354
Just replaced all ignition components on a '75 E/rude 6 HP.
My OEM manual shows a few special tools for testing and one that looks a bit like a lawn mower blade for setting the points.
The principle appears to be that setting the precise opening spot will give you the correct gap/dwell and you do this by electrically determining when the points just open.
Personally I find this type of adjustment more accurate than feeler gauges, but that is just me.
On the flywheel it looks like there are point setting marks that mean that you don't need the "LAWNMOWER BLADE".
What the manual does not mention is specifically where the advance should be when using this method. do you justhave the throttle set at idle?....no advance?
Anyone know?
Anyone know?
