Re: 6 HP Rude Fisherman Running Rough
My suggestion is to buy an OEM service manual for your motor. They are available right here at iboats. Once you get it, read through the trouble shooting section to see what conditions might fit your symptoms.
I also suggest a compression check of both cylinders. Doing so will give you some sense of whether or not you have purchsed a "turkey." You will probably get readings in about the 80 pound range, if the powerhead is healthy. As long as those values aren't extremely low (under 60), and are within about 10% of one another, you probably have a relatively decent powerhead. If there are no obvious signs of major mechanical problems, especially the gearcase, you've probably got a nice little motor.
The good news is that the 6hp OMC motors of that era are extremely simple. They will run or not run based upon three very basic things - fuel, ignition and cooling. With the factory manual, you can check all three things easily, and should soon find your problem. Going through the process will also provide the benefit of teaching you a great deal about your motor.
BTW, your motor has a fixed high speed jet in the carb. Since you have been fooling with the low speed needle valve without knowing exactly how it was set to begin with, I recommend a complete readjustment. Screw the valve in until it seats gently. Do not overtighten the valve because you will indent its beveled edges if you do. Then turn it back out 1 and 1/2 turns. That is your base point for adjustment. Next, put the boat in the water, secure it to the dock firmly, start the motor and place the motor in forward gear. Set the throttle to the "slow" position, which should yield about 700 - 750 rpm. Now adjust the needle valve until the motor runs the fastest and smoothest. Once you do this, reset the plastic knob on the needle valve to the midpoint of the adjustment range, indicating the "normal" position.
If this doesn't fix your problem, its time to run through the troubleshooting items in the OEM manual. I'm sure everyone here will be more than willing to run through those steps, as you do them.
