loiner1965
Thread starter- Joined
- Sep 28, 2012
- 77
My 1967 6 hp as a very loose throttle and if you take your hand off it will go past the position where it should idle and then die. Removed the handle and they is no spring, friction collar nothing etc Are these cheap to buy and ship to the uk.? Motor as no stat in which I have ordered and the motor was hot to touch. Checked and ordered impellor but it was fine, removed exhaust cover and back flushed the water ways and poked the two holes I saw just in case. Filled tub with clean water and started her up Ore powerful spray and it was cold whereas before it was hot.....I can now rest my hand on the engine when it's running......
