60 Evinrude Low and High settings
603tehe
I need to know what the low and high settings are for my motor. Also, the procedure to adjust them once the engine is started. Anyone help?
CATransplant
Re: 60 Evinrude Low and High settings
Hi,<br /><br />There's not really enough information there for people here to help you. What model number is on your Evinrude's model and serial number plate (at the front of the transom mount)?<br /><br />As always, the more information you provide, the better able are the volunteers here to give you the help you need.
Joe Reeves
Tehe1.... Although you received the proper information, I'd suggest that in the future you define what you're looking for, such as.....<br /><br />High and low of what.... spark advance, carb setting, engine height, etc. Gotta spell it out in order to obtain the proper answer.
603tehe
Thank you very much! That is is exactly what I needed.
Hurricane73
i dont know exactly how to do the low side,but the high side give it almost full trottle and turn the high side,if u here a put,put,turn it back,but when u find that magical spot u will deffently know.
