yatabata
Thread starter- Joined
- Oct 18, 2015
- 22
Hi Tex, I got back to the engine the other day. After checking the settings started it up and runs at the correct idle now but rough. I don't think the timing is correct like you said. I looked at everything and found two things I don't like. At the low idle timing the upper part that goes into the flywheel opening is riding not allowing to adjust the timing lower. On the other side of the engine where the oil adjustment is located the rotating plate is also riding not allowing the throttle plates to close all the way? So where to start first to get this set up right? Thanks
