60 hp Johnson headgasket
Sugo
How can I tell the difference between a blown head gasket and bad compression due to a worn cylinders and worn rings ? What are the signs of a blown head gasket vs worn cylinder and rings. I am experiencing 1/3 RPM at WOT (Only under load) and I have checked the fuel lines, fuel pump and cleaned the carbs, but still no luck. Any ideas would be appreciated.
Thanks
samo_ott
Re: 60 hp Johnson headgasket
A Jhonson? I think I've heard of that. That's that knock-off outboard engine from China right? :)
Have you taken the compression? what are the #'s? Have you taken the head off? How does it look inside? are they scores or any marks on the cylinders? If in doubt you could simply buy a new head gasket for $25 or whatever it is and try it out.
Sugo
Re: 60 hp Jhonson headgasket
Good Idea thanks,
tashasdaddy
what are your compression numbers, could just need a decarb.
Sugo
I do know the basics but still learning, what is a decarb ?
Thanks for your time
