Hi, I have a 1991 Johnson which would not start. I took it in to a local repair shop and they found nothing but oil in the carbeurator and in their words, everywhere. They cleaned it all out and returned to me saying it's now running good. I took it out on the water and it starts just fine alright but as soon as I put it into gear it dies anywhere from 10 seconds to 3 minutes later. It sputters and coughs then stalls. It is pushing a lot of blue. Took it back and all they did was adjust the idle speed. I took it back out and same problem if not worse. In the research I've done I'm thinking it may be the VRO pump being faulty or the fuel pump in some way. I'm not very literate on motor mechanics though and have little faith in the local shop. Anyone have any thoughts on this? It seems to run fine in nuetral for quite a while without stalling, but does push A LOT of blue. The motor also runs fine at full speed. I can get top speeds as I always have in the past. I have eliminated bad gas as a possible cause.
