the motor was running great since a full rebuild last winter, then last week I had to change the filter bowl gasket on the water because the methanol in our gas out here ate it. Then I did the de-carb over the weekend. Now it will only make 4000rpm at WOT and starts stumbling when the cruise throttle kicks in. seems to run fine other than at WOT, fuel bowl is full, and pumping the bulb doesn't help.
Any ideas of what may be going on? any other rubber parts the alcohol eats up that I need to keep an eye on?
I backed the high speed needle all the way out to try and clearany gunk out, but I will pull it this morning along with the flywheel and have a look, but I'm not really sure what I'm looking for.
TIA!! Joe
TIA!! Joe
