jiveturkey1
Thread starter- Joined
- Jun 30, 2017
- 17
Hi. loving my new old boat.
Having an issue though. She runs great for about an hour then at full throttle bogs down and dies. It'll start right back up and idle fine. Pumping the bulb will get it back up to speed for a while but not very long.
Here's some things I've done to it before or after it started to do this:
Installed a water separator (before)
Changed the bulb from horizontal to vertical (still using old bulb) (after)
New fuel lines to motor but not in the motor (before)
Did a Seafoam shock treatment (before)
My ideas or friends suggestions:
Rebuild fuel pump
New fuel lines in motor (maybe collapsing after getting warm?)
Gasket from carb to motor (letting air bypass after getting warm?)
Rebuild Carbs
All of the above
The mystery to me is why it runs good for an hour then gives up??
Thanks!
Rebuild fuel pump
Rebuild Carbs
All of the above
Thanks!
