MassillonBuckeye
Thread starter- Joined
- Jul 26, 2010
- 400
Hoping the gauge is broke or it wasn't sealed properly.. Going to try a different kit this afternoon weather permitting. Seems awfully low compared to everything I've seen trying to search for low compression issues here.. I freaked out after the first cylinder I tried so I didn't test the others. Partly because of the low reading, partly because I then couldn't remove the test device from the plug hole.. I ended up getting it out, but I don't think I like the design on that kit. I cannot torque the test past finger tight(twisting the hose). Has O-rings on it, so it may be sealing? http://www.autozone.com/autozone/accessories/OEM-Compression-Tester-Gauge-Set?itemIdentifier=424906
That is the kit.
I don't think I did the test quite right and not sure how that would impact readings. I didn't have the throttle open at all, engine was cold(45 deg F.) and I'm not sure if I had a good seal with the tool. Only cranked the engine about 3 times, on two different occasions and got similar results. Going to try again tonight with some 30w oil if I get low readings. I have some seafoam, so I can decarb, but it doesn't seem worth it on such a low reading. How much could it realistically increase with a decarb? 5-10 PSI?
I bought the boat right after Thanksgiving. We started it without much trouble and it ran in his driveway. Would the motor still run with a compression reading that low?
Any input is greatly appreciated.
That is the kit.
