60HP johnson-won't idle
limoguy101
I have a 1987 60 HP Johnson, When I run the motor with a flush on a hose the engine runs fine. When I put it in the water it will not idle. When I put it in gear and hit the choke button at the same time I can get it to go. If I get it in gear and it does not stall it runs fine throught the upper end. I have had the carbs off and have cleaned them and put rebuild kits in them. I have also cleaned out the fuel tank. The idle adjustment is scrwed all the why in till there is no more adjustment. I don't know if I need to sync the carbs or how to do this. I have had the timing checked and that was alright. Compression is 115, 115 110. New spark plugs, water pump, impeller and fuel filter.Any help would be apprciated.
Thanks
