physiksgeek
Thread starter- Joined
- May 10, 2005
- 15
Hello again everyone?.I will try to keep it concise but there is a history to this motor that may be helpful.
I have a Mariner 60hp, 3cyl, 2 carbs with a serial number 0B358238 (1988?). I got the boat probably 5 years ago and have mainly used it to troll the creeks because it is so unreliable. It did not run well then?.intermittent ?no power?, plowing through the water, not getting up on plane, etc. This occurred more often than it running well. When it did it would run very well, when it did not it was very frustrating. I fiddled with it for months until I finally took it to the dealer and had the carbs rebuilt. The first time I went to take it out after the repairs I found the transom was completely rotted out??Fast forward to last Thanksgiving (the boat has sat for 3 years now). I redid the transom, got it all put back together and took it out yesterday. It did not run well again but it did run better more than not.
Question ? where would you start? What troubleshooting flow would you use? I read the threads about no power and stator issues and it all sounds familiar. The plugs are new NGK?s. The batteries are a week old and charged. The engine was run till it ran out of gas before it sat for the last three years. Clean the carbs? Adjust the carbs? It is a brand new gas tank but the lines are the same. I smell heavy gas like it is either getting to much or not burning it at all. I was never able to check the repairs so it may have not been fixed then.....or it may have fixed it and now the carbs are gummed up again?
I am currently looking for manuals so I do not have the manuals yet. I would appreciate if someone could post the stator checkout procedure for my engine. I would like to rule that out first I guess before I open the fuel system again. If any more info is needed please let me know.
THANKS in advance....
