Hoping to get some help on reviving this motor, when I got it it would turn over but not start. The metal cap on top of the starter that holds the wiring for the light bulb was not screwed on and the red wire which is the positive for the light bulb broke and touched the coiled up piece of metal right next to it. You can see in the pic the red wire on the far left which I have repaired and the coiled piece it touched. When it touched the coil there was a short and ever since then it will not turn over. The solenoid will click but nothing else, any ideas what might have happened? I assume I fried something.
Second question, any idea how to get to the actual starter, I removed 3 long screws that screwed in from the top down into the base that the starter sits on. Won't budge, do I need to use penetrating oil and put pressure on it? Or do I need to remove the big flat head screws that circle the starter? See pic and thanks!
