Re: 60's model 40hp johnson
Well, I gotta tell you, those old 35's and 40's are quite forgiving motors and pretty darned tough. I picked up three of these darned things last Fall for $50. A '58 Lark 35, a '61 Lark III and a '62 Lark IV. The old 35 was laying in the floor of a boat, with the flywheel off and the coils exposed to the weather, plus it was stuck. That was the first motor I started in on. I sprayed the heck out of the cylinders with WD-40 and started tweeking on the flywheel with my hands. Once I got it free, I went through the ignition system and got it running like a clock. After about an hour or running, It tested out at 130 psi in each cylinder. The '61 Lark III tested out at 120 per cylinder and the '62 Lark IV tested out at around 110 each. When it was said and done with, I ended up with three good running motors with only a $67 investment for a new set of coils and wires on one. So the bottom line is, unless these old 40's been run out of oil, it's pretty seldome that anything would nuke one out. You can pull the bypass covers off and get an idea of what the pistons look like. You can see if there is scoring causing it to be stuck. One of these that has been run without oil, will score the pistons up pretty badly, before they sieze up. If you look in there and don't find any scoring, then it's pretty safe to bet, that it got stuck from sitting and not much will be needed to free it up. Tilt the motor up and fill the spark plug holes with a 50/50 mix of ATF and acetone and let it sit for a few days.
Yea, I know about the fever. LMAO!! I've got it too, but not very bad. My collection is only up to 12. If I could find good enough deals, then I would add 12 more in a New York minute.
