actionjackson
Thread starter- Joined
- Apr 2, 2009
- 37
'62 rk 24 40hp superseahorse, this weekend i noticed that the water seemed to slowly decrease in amount coming from the ehaust port on the back of the motor, however when i unhooked the water choke there was plenty of flow to the choke. is there a way to backflush this through that ehaust/water exit? and is the tail piece behind the prop also a water inlet where that screen is? if so does there usually drip a creamy substance after trailering home, if this is plugged can I remove that and clean it out? I know that there is an inlet on the side of the tail I opened that one and cleaned that during water pump install
