62' evinrude comp. question
zgbgwfs
I just ran did a compression test on my 62' 40 hp evinrude. Model # 35531. I understand it is supposed to be even in both and around 90 psi. I had 46 and 48. I used the pull starter, would this make a difference?
lindy46
Re: 62' evinrude comp. question
Does it have electric start? If so, try that. Pretty hard to pull a 40hp motor and get representative compression. At least they are about the same both cylinders.
jasper60103
I tell yah, I couldn't get more than 70 psi on my '62 28hp. It's a hard pull, and I almost tipped it over the stand, LOL!
They say it's easier to pull when it's on a boat. I haven't tried that yet though.
zgbgwfs
Well, I hooked up battery and got it to 58 and 60. I am going to try putting some pb blaster or mystery oil in the cylinders and let it soak for awhile before I go any further into the head. which one would you use, pb blaster or mystery oil?
zgbgwfs
Well, I put in some PB blaster in the cylinders and was able to get 70 psi in both cylinders with the pull start after it soaked for awhile.
Chris1956
Honorary Supreme Mariner
70PSI is pretty marginal. Pull the transfer covers and have a look at the rings and cylinders.
kenmyfam
Having said all that a lot of testers will vary with their results. Try it on something else like your car to see if it is just a low reading tester unless you have got better results with the same tester previously.
