Brianjason6
Thread starter- Joined
- Aug 21, 2009
- 116
What are the chances of my fuel pump being bad? These things considered.
100psi compression each cylinder, good fuel mix, good clean carb and filter, new plugs, coils, point, etc. I'm not getting fuel. Pump the bulb and it runs. Stop and it dies. The vent is open. Even tried with the gas can lid off.
I can't find a rebuild kit for my pump and want to be certain that it's the problem before I put out $100.00. Also the replacement pumps look to be the square 2in pumps. Mine is not the same. Will these work if I do have to buy one? Thank you iboats members.
