Re: 62' Johnson 28 hp RXL-10
There is a cam that the points ride on, you set 1 set of points and then rotate the crankshaft until the cam lobe is under the other set of points and then set the 2nd set of points.
Both sets of points will NOT be open or closed at the same time.
