Pulled the LU apart last night.....and bad news.
The pinion gear was chewed up with pieces of every tooth in the case. It sounded like a rattle before I opened it, so I new it wouldn't be good. Amazingly, the drive gears were OK and it had been running flawlessly. I guess the pinion was softer to "save them" much like a car starter. The DS upper seal was in bad shape but the shaft wasn't damaged at that point. However, the brass bushing at the bottom was terrible and the drive shaft was badly grooved. I'm guessing this play caused the gear to get chewed up.
So I'm on the hunt, looking for at least a pinion gear. It seems like there have to be a lot of motors that used this same pinion. Anyone have any info on compatible motors? Maybe I can find a better shaft to reduce the play and I'll definitely get a LU seal kit.
If I can't find a pinion gear, I'm going to replace the seals, bolt it back up and run it until it stops!!!! Hopefully, good oil with no water could get me through the summer...although I'd be nervous everytime I went out!!!
