mstahl1171
Thread starter- Joined
- Mar 16, 2010
- 209
I had to rebuild the lower unit and installed a new water pump impeller and seals. Motor ran fine yesterday and pumped water. Today no water pumped at all. dropped lower unit and check the pump, made sure impeller is installed correctly, verified impeller key is installed. All looks fine. I also checked the copper tubes and seals. Removed the thermostat and boiled in a pot of water to confirm operation. Is there an easy way to test for a blockage in the powerhead? Could the impeller be bad even though it is new?
PS...I removed the thermostat and tried running the motor at the ramp..still did not pump.
