6207 upper main bearing .. Question..
rk970
I need to replace the upper main bearing on my 86 125hp. The bearing # is a NTN 6207 CT2 C4. It has a plastic bearing cage.. I can find 6207 C4 bearings but they all seem to have a steel bearing cage.. Is it ok to use an upper bearing with the steel bearing cage or should I spend 3x to for a bearing with the plastic bearing cage..
Robert
ondarvr
You already have several different metals involved, it's not an issue.
rk970
The three (908h4b, 2 from 1258x5a) crankshafts I have the upper bearing is a 6207 (C4 clearance) and all have plastic cages in them.. The upper bearing does not get a lot of lubrication. .
Any hoo.. Most 2cycle motorcycle builder use bearings with the glass reinforce plastic cages.. It may have to do with a steel bearing cage running with little lube generating excessive heat.
