Won't start without ether. Won't idle low and dies after 3 seconds when you idle high. The carb is real clean although the float itself is original and looks it. New gaskets and the float needle looks good. Readjusted the high and low jets 3/4 turn like the manual says. I noticed that when I squeeze the primer bulb bubbles come out from around the fuel line where it goes into the fuel filter. Also the fuel line into the carb does not have a clamp around it. Could my problem be caused by lack of pressure and not enough fuel getting into the carb? I also replaced the gasket in the fuel filter with a homemade version - could the hole pattern in the new gasket not be right and be an issue? Maybe a choke issue? Maybe flooding - how do you know if too much fuel or not enough?
