KewlBird
- Joined
- Oct 6, 2007
- 247
Hi, the issue: I have a lot of exhaust coming out of the pee-hole and barely any water. After messing around with everything and replacing waterpump I still have a lot of exhaust coming out but not much water out of the pee hole. Finally today I was blowing air into the exhaust pipe when I noticed that it was loose and air was coming out of the pee hole. I disassembled the motor to find that all 4 bolts holding the exhaust pipe are half way out and the upper exhaust pipe gasket only had about a 1/4 of it left. So that right there may have been the problem. But while looking at the housing I noticed two openings that I don't think should be there. They are located by the lower exhaust pipe sealing ring (see the images). Now, the question is if this is normal or is my housing toast? If those openings are there they will definitely shoot exhaust up into the cooling system. Thanks.
Should those openings be there, or is the housing toast?
http://home.comcast.net/~sulejman/exhausthousing.jpg
