'63 75Hp Johnson Slow and Sucking Gas
samuelcosmoschiff
Hey all... Yet another problem with the old motor...
Johnson 75 horse V4AL-15E.... Pretty slow at wot, and I only got about 30 minutes of running out of 10 gallons of gas (the trip ended in an $85 tow back to the marina after i got stuck in the middle of the lake).
Before I ran out of gas, however, she started to pick up and I was zipping around for about 5 minutes. Also, she only likes to stay running with the choke in the "on" position; putting it to "automatic" or "off" results in a few minutes of running and eventually quitting.
Waddaya think? I was going to do a tune up to start...
boobie
Re: '63 75Hp Johnson Slow and Sucking Gas
When you start to do the tune up look closely at your fuel system. Fuel lines, fuel pump and carb.
samuelcosmoschiff
Sorry for the long delay, finally got back down to the boat earlier this week.
Replaced the plugs to the correct J8C (instead of J4C that was in there), fuel filter, and lines.
Still running kind of crappy, so I added a bottle of seafoam to a gallon of gas and ran it through. An incredible amount of smoke came out of the engine, and I think it helped some, but still not perfect. At WOT she will go about 10 mph (according to my GPS). However, after ten or so minutes at WOT she picks up and gets up to 20 mph. Still burning lots of gas, too; almost half of a twelve gallon tank in 30 or so minutes.
Any thoughts are much appreciated. At this point I'm thinking I'm going to go for round two with the seafoam...
Chris1956
Sounds like she is only running on 2 cylinders. Check compression on all. Pull the pulse line off the fuel pump and see if any fuel comes out. Also sounds like the carb is clogged. Seafoam may (may) help a little, but likely not enough. See if you can get a carb kit and clean her up.
boobie
J8C ???? Where did you get that info from?? The correct plug is J4C or you might get away with J6C.
boobie
What's the compression on it?? Will the spark jump a 1/4 " open air gap on all 4 cyl's ??
samuelcosmoschiff
Yikes! J8C was listed in the champion book. I guess I should have stuck with what was in there before. Did I do any damage by using the wrong one?
samuelcosmoschiff
Also, I didn't see if the spark would jump, but I did ohm out all the wires and they read good... 1 ohm on all. They're pretty nasty looking though, so I'm in the process of finding a new set.
boobie
If you didn't run the J8C's for long you should be okay. Read post # 6 again.
samuelcosmoschiff
Not sure about the compression, don't have a gauge but will pick one up.
Do you mean will the spark jump when I hold the wire end a quarter inch from the block?
DMontana
You can buy an adjustable spark gap tester at just about any auto parts store, and set it for the desired gap.
samuelcosmoschiff
Good spark on all cylinders. No gauge but when I turn the engine by hand it feels like it has even compression (is that valid at all?).
I also rebuilt the fuel pump, because I needed a filter and the kit came with one for $15.... not bad.
On to a carb rebuild I guess...
samuelcosmoschiff
Rebuilt the carb. Man it was dirty!
Performance improved substantially. The boat moves nicely now, although it still takes the engine a few minutes to reach top rpm.
Anyone know what the points gap is on this engine?
samuelcosmoschiff
Finally got a compression gauge...
80 PSI on all four cylinders. Is that good or bad?
Chris1956
That compression is acceptable. The fact that it is even is what is important. I expect your compression gauge reads low by 10PSI, as 90 PSI is pretty normal for those motors.
samuelcosmoschiff
That could be, it was a cheapo gauge from ebay.
So the compression is ok... why am I not getting up to speed until she's run at wot for a while then? What the heck am I missing?!
Just to re-cap:
-New plugs
-New Wires
-Spark is good
-New fuel lines and filter, pump rebuilt
-Carb Rebuilt
-Cleaned and gaped points
-Doesn't reach top rpm until run at WOT for at least a few minutes, sometimes not at all
Again guys, thanks for the help :)
Chris1956
What do the spark plugs look like? Maybe you are missing on one plug sometimes? What size and type of boat? You cleaned and gapped both sets of points, to .020?
samuelcosmoschiff
The plugs look good.... light brown, not fouled.
Its an 18ft tri hull bow rider. Yep, cleaned and gapped to .02.
pn
have you tried pumping the primer when it luggs. a boost would indicate fuel flow.
