floatingwoody2006
- Joined
- Feb 2, 2006
- 500
HAs 96 lbs compression per side. Bright blue snappy spark, but will not fire up. Carburation aside, wont even fire with fuel in the plug holes. Had it running but discovered the needle tip broken in the carb. Had to drill it out. I know it will run poorly maybe until i can get another carb, but what on earth would stop it from at least firing with fuel in the hole?
