powerwagon
- Joined
- Apr 27, 2009
- 8
Need help.......1963 40 hp Johnson motor model RDS-25D is not running right. Bucks or jumps no matter what speed when in gear. Does not do it in reverse. Is very hard on fuel and not sure if this has something to do with the problem (6 miles to 4 gallons of gas). Disassembled prop to check gears and they appear to be intact. Roughly how fast should this motor move a 17' fiberglass Lonestar boat? At first we thought the motor mount was loose and was jumping when moving. It is almost like the gears are slipping. Any thoughts would be appreciated. The motor jumping happens approximately every 6-7 seconds no matter the speed.
