Bought it last yr,would start and run great for about 45 seconds. Bought fuel pump kit and carb kit,cleaned real good,used compressed air,reassembled,adjusted per instructions,double checked everything. It will start and idle for MAYBE 30 seconds and die like it has no fuel. Checked everything from tank to float bowl,all looks good. Any ideas???<br />UPDATE!!!!!!!<br /> Problem appears to be check valve on inlet side of fuel pump....can this be cleaned or is it just as easy to order new kit?
