'64 16ft OMC boat, transom is mush
markedman
I'd like to know the best way to start a repair like this. Is the best way to remove the top or just cut away as much as I need to get to it? I've pulled off some of the metal edging and it appears that the top is bonded to the hull. (a flange joint I think it's called). I also have a leak in the keel of the boat. It will drip on the driveway for 2 days after I have it in the water. Any thoughts anyone?
SpinnerBait_Nut
Re: '64 16ft OMC boat, transom is mush
Welcome aboard.
This needs to be in the boat restoration forum where it will go now.
Ayuh,.....
Usually after you pull the Rub Rail off,... There's screws or Rivets holding the 2 pieces together.....
markedman
Thanks for the info, the "good reading" was exactly that. It looks like I'm in for a lot of work. I've read a few entries about removing the top, but am still puzzled. I haven't seen a step by step process for doing that. I've removed the rub rail and the screws and T nuts but the two haves are bonded and there is a 3" wide band of material on the inside that has been glassed in to hold them together. Looks like a dog to cut through. I'm thinking of using a demo saw and a thin blade. Can you tell I'm a newbie. Once I get the lay of the land and a feel for the materials I think I'll be OK. I'm good with tools , done a couple home renos, car repair, body work, plumbing, electrical, welding, machining and other stuff , but all non- proffessional. So thanks in advance for the help, and I'll try not to ask anything too Duh-mmm
Nawww,.... No Such Thing,........;)
Welcome Aboard............
Coors
Search in here, plenty of opinions, and plenty of pics.
markedman
Somebody shoot me! I need to untie the anchor and tie it to a new boat. Looks like a total rebuild for me. I pulled up the carpet and the floor is totally gone. Did some of the reading suggested here and see that I have a few hundred hours of work.To bad I dont have the money for the new boat. But I'm Cheap and just Duh mmm enough to keep going. I'll post Pics if I ever figure out how. Thanks again for the direction.
Say anyone done a job on this model boat?? Its a 1964 Sweet 16 by OMC
