tootallofwa
- Joined
- Feb 20, 2010
- 180
64' 18hp fastwin Impeller doesn't pump water after replacement & other circumstances
I need to know if the impeller can be checked by removing the thermostat, Before I pull the thing all apart again.
I borrowed a 64' 18hp fastwin from my cousin that wasn't running. He had it in saltwater last time out. It was seized so I oiled the cylinders and breaking it loose was not hard. I rebuilt the carb, repaired the broken fuel pump, shift lever, throttle handle and prop nut. replaced the plugs and wires, fuel lines and sync'd it. Cousin ended up giving the motor to me.
I had it running pretty good but it was leaking gear oil.
I pulled the lower unit to replace the drive shaft seal and impeller. I was plagued by broken bolts, stripped threads and a drive shaft seized to the crank.
Try and try to free the shaft became futile when I realized that the shaft seal was below the the impeller drive pin. The Drive shaft did not budge with a 4' pry bar and vice grips clamped on just below the upper exhaust housing (only the vice grips moved.)
I filed the burrs from the drive shaft I'd made in my efforts to budge it, so it would fit back into the pinion gear. Heli-coiled my stripped bolt holes, hammered flat the impeller plate, installed the new seal, put in a new impeller into the housing screwed it in place and carefully slipped the the the lower unit into place over the shaft. Bolted it back together and started in a barrel. (twice)
I'm not terribly confident the pin is in the impeller because it's not pumping water now (it did before.) But I don't know how it would bolt together if the pin is not in the impeller slot. I was careful to line the pin and water line up before fighting the shift linkage.
I haven't checked the thermostat yet...
Next step is to measure to insure the pin is in the impeller slot. No way to free the drive shaft to assemble the easy way.
Thoughts?
Thoughts?
