64 3 hp Johnson
jwh
Hi All,
Just installed new points, condensors, coils, plugs in my 3 hp johnson. A friend said before I try to start it I needed to time it to make sure the gap was right on the points(.020) at the (top) of lobe. Is this necessary? Thanks for any info. John
kbait
Re: 64 3 hp Johnson
Absolutely. Must be gapped to .020" on highest spot on lobe. LOTS of info if you search this forum..
Good luck!
jwh
Re: 64 3 hp Johnson
How do I time it ,with what ? Thankyou John Wow nice fish
kbait
Re: 64 3 hp Johnson
Timing is accomplished by point gap on universal mag motors lik yours. You can check it w/timing light if you wish (flywheel mark/armature plate mark), but you'll find it's very close if points are set properly to .020" and no excessive armature plate wobble.. good luck!
jwh
Re: 64 3 hp Johnson
Thanks much you guys are great
1946Zephyr
Re: 64 3 hp Johnson
Those are great little motors. I have a couple of those, myself. Take good care of it and it'll run forever. Run the fuel mix at 24:1 or 16:1 to ensure the longevity on that motor. The 3hp of your time frame stated 50:1, but that's a mistake. There's no needle bearings in that motor, so it'll need the same fuel mix as the older motors. I prefere 16:1 in that particular model, but some here will tell you that 24:1 is good.
jwh
Re: 64 3 hp Johnson
boy you guys are like having a built in marina at home. You are all awsome. John That is a terrific link. I printed it all. Thankyou
