Evinrude Boater
Thread starter- Joined
- Jul 6, 2004
- 1,148
I had the starter rebuilt for my 1964 75hp Speedifour. When I put it back on the motor I found the bolt hole stripped for the lower support bracket bolt. I think it bolts through the front crank case into the cylinder block. It's so low on the engine that it's hard to get at and I don't think I want to have it tapped out for fear of damaging it more. I hope the crank case seal doesn't rely on that bolt. Should I bother trying to get that bolt tight or will the starter be fine bolted through the upper mount into the starter drive?
