Re: 64 9.5 fuel delivery questions
Got it all back together and idling without the choke. I think the debris in the high speed jet was the issue. Put the extra fiber washer in the needle valve packing also. Running it in a trash can got it to idle fairly low. Put the cover on and it started running rough. Richened up the mix and it ran better. Didn't see any smoke coming from under the cowl area, but I mixed the gas a little more oil than normal because it hadn't run in a while. I think I wil wait and try to fine tune it on the water. Thanks everyone that showed me what to do. It is greatly appreciated. One more question. What do you do with the skanky water left over in the trashcan???
