64 Evnrude Big Twin 40 hp Compression, and missing pieces???
Sea Raider I
Just bought this for $100 bucks, not sure if I just purchased a parts motor as it seems like pieces are missing. Can anyone identify what is missing from the pics? I am completely unfamiliar with this motor. When I bought I did compression check with both plugs out both cyl are exactly at 95psi, is that adequate for this motor. Can I expect continued use with a restore/tune up? PO said it ran before it sat. Pistons and cylinder walls look to be in fine condition with exception of some minor carbon build up.
Any advice/wisdom appriciated...
Thanks
F_R
Re: 64 Evnrude Big Twin 40 hp Compression, and missing pieces???
1. The vacuum cut-out witch is missing.
2. The starter safety switch is disconnected (because of #1)
3. The automatic choke heat tube is missing
4. The automatic choke is missing also. So the missing heat tube doesn't matter much, does it?
samo_ott
Yes, it looks like it has been converted to a manual choke. I have the parts manual if you want it, it would help see what you're missing. If you want it, PM me your model # and email address.
