65 HP 3 cyl Merc piston cylinder question
nowheels22
Hi, this outboard is 1973 (i think) it overheated the top cylinder. Compression is now 60 psi. I looked thru the exhaust port and there is damage. It never seized.
I am wondering it the cylinder is a cast sleeve or plated with something. So, can i hone it?
Thanks is anyone can help.
Faztbullet
No it is cast iron and all three will likely needed bored due to wear and out of roundness. Hone wont fix it....
nowheels22
you are absolutely correct. i went to the Wiesco site and they have the correct pistons. thanks.
