65 hp suzuki trouble
fishgigger
Hi, new to the forum. Have a ? hope can be answered.
I have a 1986 65 suzuki, it is a 2 stroke, 3 cyl. it had to sit for about a year when I went oversesa for a job, when I came back it would start and run fine but bog when under power, had carbs rebuilt and new fuel pump and still does same thing. Tried hitting the choke when it bogged which shut it off, crank right back up and idle all day long buttry to go and it will take off fine then bog with intermittant spots of it taking off like a rocket for a few seconds and then bog again for awhile. Anybody ever have this happen????
Thanks
Re: 65 hp suzuki trouble
i have a 95 dt65 and i changed the plus and replaced th tank , 6 gal , and ran aviation fuel , it cleaned it right up , check gasket in the rear outside fuel pump , and use about a cup of aircraft fuel , it worked for me good luck
