65 Hspr. 1972 Evinrude
SkipMoss
Is there a way to remove the solonoid, ignition switch, and safety switch, and test them seperately, apart from one another.<br /><br /> Thanks for the help,<br /> Skip
R.Johnson
Re: 65 Hspr. 1972 Evinrude
Yes! All you need is an ohm meter, you will need a battery to trip the solonoid.
SkipMoss
Let's start with the ignition switch. It has five screws with wires attach to each, some with more than one wire on it. What's the procedure for checking this out with the ohm meter independently from the solonoid and the safety switch.<br /> Thanks <br /> Skip
