650 Merc no fire to coil
achris
More fish than mountain goat
Re: 650 Merc no fire to coil
I have the procedure and if you post your e-mail address I'll send it to you.<br /><br />Chris...............
mwbaughan
thanks Chris, maybe I can find a used distributor
achris
You'll still need the setup procedure. I have it and will scan and send to you.<br /><br />Chris..........
achris
You have mail.....
laymans terms...any chance have you removed the distributor cap to see if the carbon electrode(on a spring) that makes contact with the centre of rotor is in one piece? I recently had problems with our engine. Checked and found no spark to plugs. Checked wire connections on cap, removed cap and found carbon electrode had blew apart hence no spark. Just my two bits, after repair we are back on the water.<br />Cheers DT
achris
DT,<br /><br />He had no spark from the coil. That sorta rules out anything 'downstream' of the coil. We got spark by imitating the trigger at the powerpack, so it's the trigger that's crook.<br /><br />Chris.........
