65hp Mercury Outboard
brakeman
Will not start up. Had in water and it started after a few trys, and stopped , would not start back up. Brought back up on land and still wouldn't start. It cranks ,but won't start.
steelespike
Re: 65hp Mercury Outboard
Spray wd40 in carbs and try. if it fires you<br /> have a fuel supply or choke problem.<br /> If the motor hasnt run in sometime you should<br /> check the fuel system from tank to carbs. <br /> If motor doesnt fire check for spark.Chack the kill switch or ignition switch should be open to run, closed to stop.<br /> Good luck.
brakeman
Thanks for the info Steelespike, will try it tomorrow. Worked on it enough today.
brakeman
Steelespike, this is brakeman again. I still can not get this motor going.(65hp Mercury) I relly need help
chuffo
I have compression on cylinder 1: 120 2: 125 3: 128 4: 50 is this lost cause or what. Engine 1971 650 mercury
