'66 110 prop replacement
rustvyper
does anyone know where I can order a replacement prop for a 1966 110 9.8hp outboard? I've got the boat down here at the coast for a week & the bushing has broke loose from the fitting & prop. Of course all the prop repair shops & merc dealer no longer deal in such old stuff...any help would be appreciated! Thanks!
dajohnson53
Re: '66 110 prop replacement
Rustvyper - My first and quickest choice would be a Merc dealer - will have a prop for you for around $80. It is a common prop for older Merc 110's. Also, the same website you looked at for your carb problem will have a prop part number for your engine if you search. The original prop number will probably be NLA, but there will be one or more choices (one or more two and three blade) with current part numbers. Price will be about the same as local, probably, but it will give you a part number to work with. I'd look at a dealer first.
