Re: '66 Evinrude Sportwin 9.5 HP shifting problems
I've been looking at the exploded views for your engine (or a '68, the closest I can come.) I can't find an inspection plate on your lower covers, but the shift linkage clamp is in there somewhere. Look on your engine for a little plate on the midsection. It'll have 2 screws, which you have to remove. That should give you access.<br /><br />However, it may be, on this engine, which has two covers which bolt together and form the midsection, that one or the other must be removed completely to access the clamp.<br /><br />In any case, the rods have a groove on the ends where they enter the clamp. The groove must match up with the clamping bolts, since that's actually what holds them into position. In many cases, these darned things get stripped by over-tightening. The clamp is still available, so if yours is stripped, you'll need a new one. It is just possible to fix these, but I'm not going to get into that, since it's a bodgy operation, and shouldn't be used if the correct part is available.<br /><br />Again, you'll need a manual for this repair...no question about it. If you have to split the midsection, there are all sorts of seals, bushings, rubber gaskets, and the like that have to be installed correctly.
